Einleitung
HTC is now known for there audio quality. The bottom speaker is a major item in the device so the user can have the full HTC sound experience. This guides purpose is geared towards the user replacing the speakers.
Was du brauchst
Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
Using the T5 screw driver remove the remaining screw at the bottom right corner of the phone.
Lift and remove black plastic casing with a nylon spudger to access the motherboard and speaker.
Using the PH000 unscrew the following screws that are holding down the motherboard.
Gently disconnect the wire located on the right side of the device from the bottom motherboard .
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Where do you acquire new speakers? Can you tell me if the speakers are as powerful as the ones in the M8
