Zum Hauptinhalt wechseln
Verizon Ellipsis Jetpack MHS800L Screen Replacement
Was du brauchst
  1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: Schritt 1, Bild 1 von 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: Schritt 1, Bild 2 von 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: Schritt 1, Bild 3 von 3
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 2, Bild 1 von 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 2, Bild 2 von 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Phillips #00 Screwdriver
    $5.49
    Kaufen
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 4, Bild 1 von 1
    iFixit Opening Picks (Set of 6)
    Kaufen
  5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 5, Bild 1 von 1
    • Once the cover is off, this is what your device will look like.
  6. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: Schritt 6, Bild 1 von 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: Schritt 6, Bild 2 von 2
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
  7. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 7, Bild 1 von 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 7, Bild 2 von 2
    Kaufen
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
  8. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 8, Bild 1 von 1
    Kaufen
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
  9. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 9, Bild 1 von 1
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
  10. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: Schritt 10, Bild 1 von 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: Schritt 10, Bild 2 von 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: Schritt 10, Bild 3 von 3
    • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
  11. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 11, Bild 1 von 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 11, Bild 2 von 2
    Kaufen
    • Using the Tweezers gently coax the display data cable out of circuit board connector.
    • Do not squeeze the display data cable to hard you may damage it and cause a short.
  12. Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 12, Bild 1 von 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: Schritt 12, Bild 2 von 2
    Kaufen
    • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team 3-3, Baechle Spring 2016 Mitglied von IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 2,147
