Einleitung
Use this guide to replace the buttons on the back of the camera that control the various menu options.
Was du brauchst
Schritt 1 Back Case
Achtung: Die Schritte 1-6 stammen von einer Anleitung, die derzeit bearbeitet wird.
Remove all four 1 mm JIS #00 screws from the back of the camera.
Use your finger to peel the grip off the top of the camera.
For best results, start from the right side of the camera, opposite the buttons.
Remove the three 1 mm JIS #000 screws from the top.
Remove the 1 mm JIS #000 screw from the bottom.
Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
Carefully pull the ribbon cables out of their sockets.
Remove the eight JS#000 screws using a screwdriver and lift panel up.
This screw does not need to be removed.
