Einleitung
In this guide you will be taking apart the Bell and Howell DNV16HDZ camera to replace the lens. There are different lens types that you can replace it with.
Was du brauchst
Remove the five 30mm Phillips #0 screws on the bottom of the camera.
Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
