Einleitung
Use this guide to replace the rear case of the Pentax Optio WG-2.
Was du brauchst
Use your finger to peel the grip off the top of the camera.
For best results, start from the right side of the camera, opposite the buttons.
Remove the three 1 mm JIS #000 screws from the top.
Remove the 1 mm JIS #000 screw from the bottom.
Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
Carefully pull the ribbon cables out of their sockets.
