Zum Hauptinhalt wechseln
Westcott iPoint Evolution Outer Casing Replacement
Was du brauchst
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: Schritt 2, Bild 1 von 1
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: Schritt 3, Bild 1 von 2 Westcott iPoint Evolution Outer Casing Replacement: Schritt 3, Bild 2 von 2
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: Schritt 4, Bild 1 von 3 Westcott iPoint Evolution Outer Casing Replacement: Schritt 4, Bild 2 von 3 Westcott iPoint Evolution Outer Casing Replacement: Schritt 4, Bild 3 von 3
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: Schritt 5, Bild 1 von 3 Westcott iPoint Evolution Outer Casing Replacement: Schritt 5, Bild 2 von 3 Westcott iPoint Evolution Outer Casing Replacement: Schritt 5, Bild 3 von 3
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: Schritt 6, Bild 1 von 1
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: Schritt 7, Bild 1 von 1
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: Schritt 8, Bild 1 von 1
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: Schritt 9, Bild 1 von 1
    • Step 9: Carefully lift the lid off of the sharpener.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Lilly
167 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 43
Insgesamt: 11,718
