Zum Hauptinhalt wechseln
1999-2002 Suzuki SV650 Seat Replacement
Was du brauchst
  1. 1999-2002 Suzuki SV650 Seat Replacement, Seat: Schritt 1, Bild 1 von 2 1999-2002 Suzuki SV650 Seat Replacement, Seat: Schritt 1, Bild 2 von 2
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Phillip Takahashi
86.704 Reputation
87 Anleitungen geschrieben
Ein Kommentar
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 66
Insgesamt: 7,900
