Zum Hauptinhalt wechseln
HP Compaq Presario V3000 Hard Disk Drive Replacement
Was du brauchst
  1. HP Compaq Presario V3000 Hard Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 2, Bild 1 von 2 HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 2, Bild 2 von 2
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 3, Bild 1 von 2 HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 3, Bild 2 von 2
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
  4. HP Compaq Presario V3000 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 4, Bild 1 von 3 HP Compaq Presario V3000 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 4, Bild 2 von 3 HP Compaq Presario V3000 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 4, Bild 3 von 3
    • Remove the two Phillips #0, 2.0×5.0 mm hard drive access cover screws. Do not remove them fully. The screws will stay in place on the cover plate.
    • Lift the access cover off and place it to the side out of your way.
  5. HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 5, Bild 1 von 3 HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 5, Bild 2 von 3 HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove the two Philips #0 2.5X5.0 mm screws and set them aside.
    • Pull the silver tab back and up to remove the hard drive from the laptop.
  6. HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 6, Bild 1 von 2 HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift the hard drive up from the laptop. Be careful not to left it all the way.
    • Gently pull the hard drive away from the edge in the direction of the arrow.
    • There are two plastic clips on the hard drive case that insert into the laptop that may break if you lift the hard drive up too far and too fast.
  7. HP Compaq Presario V3000 Hard Disk Drive Replacement: Schritt 7, Bild 1 von 1
    • Check the hard drive connections inside the laptop casing. Make sure that they are clean from dust or debris and are straight.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ricky Jaimez
315 Reputation
2 Anleitungen geschrieben
University of Memphis, Team 1-4, Kim SU 2016 Mitglied von University of Memphis, Team 1-4, Kim SU 2016
UM-KIM-SU16S1G4
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 5,923
