Einleitung
Removing the hard drive is required when the drive will no longer boot or when you want to upgrade to a larger capacity drive. This task can seem difficult, but is not as bad as you may think! Using a magnetic project mat to hold and label the screws will come in handy during this replacement.
CAUTION: Always unplug the device from the power source or wall outlet before beginning any replacement work.
Was du brauchst
Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
Locate the battery EJECT latch.
Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
Pull the battery up and towards you to remove it from the laptop chassis.
Once the battery is out, you will be able to check the battery label for the replacement part number.
Remove the two Phillips #0, 2.0×5.0 mm hard drive access cover screws. Do not remove them fully. The screws will stay in place on the cover plate.
Lift the access cover off and place it to the side out of your way.
Remove the two Philips #0 2.5X5.0 mm screws and set them aside.
Pull the silver tab back and up to remove the hard drive from the laptop.
Lift the hard drive up from the laptop. Be careful not to left it all the way.
Gently pull the hard drive away from the edge in the direction of the arrow.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
