Zum Hauptinhalt wechseln
Sony Xplod CDX-MP30 Main Panels Replacement
Was du brauchst
  1. Sony Xplod CDX-MP30 Main Panels Replacement, Front Panel: Schritt 1, Bild 1 von 3 Sony Xplod CDX-MP30 Main Panels Replacement, Front Panel: Schritt 1, Bild 2 von 3 Sony Xplod CDX-MP30 Main Panels Replacement, Front Panel: Schritt 1, Bild 3 von 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Main Panels Replacement, Main Panels: Schritt 2, Bild 1 von 2 Sony Xplod CDX-MP30 Main Panels Replacement, Main Panels: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Phillips #0 Screwdriver
    $5.49
    Kaufen
  3. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 3, Bild 1 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 3, Bild 2 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 3, Bild 3 von 3
    Phillips #1 Screwdriver
    $5.49
    Kaufen
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 4, Bild 1 von 1
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 5, Bild 1 von 2 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 5, Bild 2 von 2
    $5.49
    Kaufen
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 6, Bild 1 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 6, Bild 2 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 6, Bild 3 von 3
    $5.49
    Kaufen
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 7, Bild 1 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 7, Bild 2 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 7, Bild 3 von 3
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 8, Bild 1 von 2 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 8, Bild 2 von 2
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 9, Bild 1 von 1
    $5.49
    Kaufen
  10. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 10, Bild 1 von 2 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 10, Bild 2 von 2
    $5.49
    Kaufen
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 11, Bild 1 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 11, Bild 2 von 3 Sony Xplod CDX-MP30 Main Panels Replacement: Schritt 11, Bild 3 von 3
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
Abschluss
Chao Chen
79 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 5-35, Amido Fall 2011 Mitglied von Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 3,599
