Zum Hauptinhalt wechseln
Removing Bottom of iMac G4 15" 700 MHz EMC 1873
Was du brauchst
  1. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: Schritt 1, Bild 1 von 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: Schritt 1, Bild 2 von 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: Schritt 2, Bild 1 von 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: Schritt 3, Bild 1 von 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: Schritt 3, Bild 2 von 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, AirPort Card: Schritt 4, Bild 1 von 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  5. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Removing the Lower Case: Schritt 5, Bild 1 von 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: Schritt 6, Bild 1 von 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873: Schritt 6, Bild 2 von 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: Schritt 7, Bild 1 von 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: Schritt 8, Bild 1 von 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 5-32, Amido Fall 2011 Mitglied von Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Do I need to apply thermal paste? Or it is not necessary?
willynanita - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 40
Insgesamt: 6,353
