Einleitung
In this guide you will be removing the side case doors. This is a necessary step to replace every other component on the HP Compaq dx2000MT.
Was du brauchst
Turn off your computer and remove the power cable by pulling it straight out of its socket.
Remove the side case door by pushing towards the rear of the device with your hand.
Once you slide the door back, remove it by pulling it outwards from the device.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
