Zum Hauptinhalt wechseln
Disassembling HP Compaq dx2000MT Hard Drive
Was du brauchst
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: Schritt 1, Bild 1 von 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 2, Bild 1 von 2 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 2, Bild 2 von 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 3, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 3, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 3, Bild 3 von 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 4, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 4, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 4, Bild 3 von 3
    • Once again, this may take considerable force.
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: Schritt 5, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: Schritt 5, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: Schritt 5, Bild 3 von 3
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 6, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 6, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 6, Bild 3 von 3
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 7, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 7, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 7, Bild 3 von 3
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 8, Bild 1 von 2 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 8, Bild 2 von 2
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 9, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 9, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 9, Bild 3 von 3
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 10, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 10, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 10, Bild 3 von 3
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 11, Bild 1 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 11, Bild 2 von 3 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 11, Bild 3 von 3
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: Schritt 12, Bild 1 von 2 Disassembling HP Compaq dx2000MT Hard Drive: Schritt 12, Bild 2 von 2
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Eva Pong
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-16, Regan Fall 2011 Mitglied von Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Mitglieder
17 Anleitungen geschrieben
2 Kommentare
can i upgrade it to 500gb?
connor gouws - Antwort
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
Thomas Daniel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 19
Letzte 30 Tage: 81
Insgesamt: 8,305
