Einleitung
RAM, or random access memory, is short-term storage for your Compaq dx2000MT. RAM is used by your processor for immediate use as-needed, unlike long-term files written to a hard disk drive. If your computer has slowed considerably or you’re looking for a boost, replacing/upgrading the RAM is a fairly simple and inexpensive first step. The Compaq dx2000MT laptop comes standard with 4GB of RAM and can be upgraded to a maximum of 8GB with its two (DDRSD) slots.
Was du brauchst
Turn off your computer and remove the power cable by pulling it straight out of its socket.
Remove the side case door by pushing towards the rear of the device with your hand.
Once you slide the door back, remove it by pulling it outwards from the device.
Remove the IDE data and power cables from the hard drive.
Remove the front bezel by pulling upwards and out from below the lowest air vent.
Remove the following screws:
Front Torx T15.
Torx T15 mounting the hard drive cage to the optical drive bay.
Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
Proceed to the other side of the hard drive cage.
Remove the two Torx T15 screws holding this side of the hard drive in place.
Remove the hard drive from the hard drive cage by pulling it outward from the cage.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
