Einleitung
Be cautious about the ribbon cable
Was du brauchst
Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
Insert the plastic opening tool along the seams at different points to it pry the clips off.
Flip up the retaining flap with your fingernail or a plastic opening tool.
Pull on the ribbon cable gently with your fingers.
Split apart the motherboard and front panel.
Remove the other yellow piece of tape off of the end of the ribbon cable.
