Zum Hauptinhalt wechseln
HTC Maple 100 LCD Screen Replacement
Was du brauchst
  1. HTC Maple 100 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 LCD Screen Replacement: Schritt 3, Bild 1 von 2 HTC Maple 100 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 LCD Screen Replacement, Back Panel: Schritt 4, Bild 1 von 2 HTC Maple 100 LCD Screen Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 LCD Screen Replacement: Schritt 6, Bild 1 von 3 HTC Maple 100 LCD Screen Replacement: Schritt 6, Bild 2 von 3 HTC Maple 100 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 LCD Screen Replacement, Motherboard: Schritt 7, Bild 1 von 2 HTC Maple 100 LCD Screen Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Remove the one 3.3mm Phillips #00 screw.
  8. HTC Maple 100 LCD Screen Replacement: Schritt 8, Bild 1 von 2 HTC Maple 100 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 LCD Screen Replacement: Schritt 9, Bild 1 von 2 HTC Maple 100 LCD Screen Replacement: Schritt 9, Bild 2 von 2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 LCD Screen Replacement: Schritt 10, Bild 1 von 3 HTC Maple 100 LCD Screen Replacement: Schritt 10, Bild 2 von 3 HTC Maple 100 LCD Screen Replacement: Schritt 10, Bild 3 von 3
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. HTC Maple 100 LCD Screen Replacement: Schritt 11, Bild 1 von 2 HTC Maple 100 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 LCD Screen Replacement: Schritt 12, Bild 1 von 2 HTC Maple 100 LCD Screen Replacement: Schritt 12, Bild 2 von 2
    • Gently pull on the ribbon cable to separate the motherboard.
  13. HTC Maple 100 LCD Screen Replacement, LCD Screen: Schritt 13, Bild 1 von 3 HTC Maple 100 LCD Screen Replacement, LCD Screen: Schritt 13, Bild 2 von 3 HTC Maple 100 LCD Screen Replacement, LCD Screen: Schritt 13, Bild 3 von 3
    • Pry the LCD screen out by using the plastic opening tool or your fingers.
Abschluss
Nick
6 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 20-29, Maness Fall 2011 Mitglied von Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 1,076
