Zum Hauptinhalt wechseln
Apple IIc Floppy Drive Replacement
Was du brauchst
  1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: Schritt 1, Bild 1 von 2 Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: Schritt 1, Bild 2 von 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Floppy Drive Replacement: Schritt 2, Bild 1 von 2 Apple IIc Floppy Drive Replacement: Schritt 2, Bild 2 von 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Floppy Drive Replacement: Schritt 3, Bild 1 von 2 Apple IIc Floppy Drive Replacement: Schritt 3, Bild 2 von 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Floppy Drive Replacement: Schritt 4, Bild 1 von 2 Apple IIc Floppy Drive Replacement: Schritt 4, Bild 2 von 2
    • Lift the handle straight up to remove.
  5. Apple IIc Floppy Drive Replacement, Keyboard: Schritt 5, Bild 1 von 2 Apple IIc Floppy Drive Replacement, Keyboard: Schritt 5, Bild 2 von 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Apple IIc Floppy Drive Replacement, Floppy Drive: Schritt 6, Bild 1 von 2 Apple IIc Floppy Drive Replacement, Floppy Drive: Schritt 6, Bild 2 von 2
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  7. Apple IIc Floppy Drive Replacement: Schritt 7, Bild 1 von 3 Apple IIc Floppy Drive Replacement: Schritt 7, Bild 2 von 3 Apple IIc Floppy Drive Replacement: Schritt 7, Bild 3 von 3
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  8. Apple IIc Floppy Drive Replacement: Schritt 8, Bild 1 von 2 Apple IIc Floppy Drive Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
  9. Apple IIc Floppy Drive Replacement: Schritt 9, Bild 1 von 2 Apple IIc Floppy Drive Replacement: Schritt 9, Bild 2 von 2
    • Carefully lift the floppy drive cage straight up to remove it.
  10. Apple IIc Floppy Drive Replacement: Schritt 10, Bild 1 von 2 Apple IIc Floppy Drive Replacement: Schritt 10, Bild 2 von 2
    • Lift the floppy drive straight up to remove.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 21-23, Maness Fall 2011 Mitglied von Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 5,342
