Zum Hauptinhalt wechseln
Samsung Captivate Rear Case Replacement
Was du brauchst
  1. Samsung Captivate Rear Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Rear Case Replacement: Schritt 2, Bild 1 von 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Rear Case Replacement, Rear Case: Schritt 4, Bild 1 von 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Rear Case Replacement: Schritt 5, Bild 1 von 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Rear Case Replacement: Schritt 6, Bild 1 von 3 Samsung Captivate Rear Case Replacement: Schritt 6, Bild 2 von 3 Samsung Captivate Rear Case Replacement: Schritt 6, Bild 3 von 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Rear Case Replacement: Schritt 7, Bild 1 von 1
    • Separate the rear case from the phone.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Christopher
643 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 20-25, Maness Fall 2011 Mitglied von Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 3,543
