Zum Hauptinhalt wechseln
HTC Wizard 200 Speakers Replacement
Was du brauchst
  1. HTC Wizard 200 Speakers Replacement, Battery: Schritt 1, Bild 1 von 2 HTC Wizard 200 Speakers Replacement, Battery: Schritt 1, Bild 2 von 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Speakers Replacement, Back Panel: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $3.99
    Kaufen
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Speakers Replacement: Schritt 3, Bild 1 von 2 HTC Wizard 200 Speakers Replacement: Schritt 3, Bild 2 von 2
    Spudger
    $3.99
    Kaufen
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Speakers Replacement: Schritt 4, Bild 1 von 2 HTC Wizard 200 Speakers Replacement: Schritt 4, Bild 2 von 2
    T5 Torx Screwdriver
    $5.49
    Kaufen
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Speakers Replacement: Schritt 5, Bild 1 von 3 HTC Wizard 200 Speakers Replacement: Schritt 5, Bild 2 von 3 HTC Wizard 200 Speakers Replacement: Schritt 5, Bild 3 von 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Speakers Replacement: Schritt 6, Bild 1 von 2 HTC Wizard 200 Speakers Replacement: Schritt 6, Bild 2 von 2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Speakers Replacement, Speakers: Schritt 7, Bild 1 von 2 HTC Wizard 200 Speakers Replacement, Speakers: Schritt 7, Bild 2 von 2
    • Device rotated 180 degrees.
    • Use the plastic opening tool to disconnect the speaker connections.
Abschluss
Kyle Champ
225 Reputation
12 Anleitungen geschrieben
Cal Poly, Team 20-27, Maness Fall 2011 Mitglied von Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 731
