Zum Hauptinhalt wechseln
Disassembling Kodak Advantix F350 Back Cover
Was du brauchst
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: Schritt 2, Bild 1 von 2 Disassembling Kodak Advantix F350 Back Cover: Schritt 2, Bild 2 von 2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: Schritt 3, Bild 1 von 3 Disassembling Kodak Advantix F350 Back Cover: Schritt 3, Bild 2 von 3 Disassembling Kodak Advantix F350 Back Cover: Schritt 3, Bild 3 von 3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: Schritt 4, Bild 1 von 2 Disassembling Kodak Advantix F350 Back Cover: Schritt 4, Bild 2 von 2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: Schritt 5, Bild 1 von 2 Disassembling Kodak Advantix F350 Back Cover: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: Schritt 6, Bild 1 von 3 Disassembling Kodak Advantix F350 Back Cover: Schritt 6, Bild 2 von 3 Disassembling Kodak Advantix F350 Back Cover: Schritt 6, Bild 3 von 3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Abschluss
UW Stout, Team 1-2, Zhou Fall 2011 Mitglied von UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 1,070
