Einleitung
This guide will teach the user how to remove a damaged SLR lens mount on the Cannon AE-1. The SLR lens mount allows the user to connect different lens to the Canon AE-1.
Was du brauchst
Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
Remove the remaining two screws from the right and left sides of the lens outer casing using a Phillips #00 screwdriver.
Remove the four #00 screws from the SLR lens mount using a Phillips #00 screwdriver.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
