Zum Hauptinhalt wechseln
Samsung ML2510 Side Cooling Fan Replacement
Was du brauchst
  1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 1 von 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 2 von 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 3 von 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Side Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Side Cooling Fan Replacement: Schritt 3, Bild 1 von 3 Samsung ML2510 Side Cooling Fan Replacement: Schritt 3, Bild 2 von 3 Samsung ML2510 Side Cooling Fan Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: Schritt 4, Bild 1 von 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: Schritt 4, Bild 2 von 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: Schritt 4, Bild 3 von 3
    • Locate the holes on the panel that are attached to the main body.
    • Remove the front panel by gently moving the holes from the pegs one by one.
  5. Samsung ML2510 Side Cooling Fan Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Samsung ML2510 Side Cooling Fan Replacement: Schritt 6, Bild 1 von 3 Samsung ML2510 Side Cooling Fan Replacement: Schritt 6, Bild 2 von 3 Samsung ML2510 Side Cooling Fan Replacement: Schritt 6, Bild 3 von 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Samsung ML2510 Side Cooling Fan Replacement: Schritt 7, Bild 1 von 3 Samsung ML2510 Side Cooling Fan Replacement: Schritt 7, Bild 2 von 3 Samsung ML2510 Side Cooling Fan Replacement: Schritt 7, Bild 3 von 3
    • Lift the right side-panel up from the raised stops.
    • Gently rotate the panel as indicated in the picture to remove the panel entirely.
  8. Samsung ML2510 Side Cooling Fan Replacement: Schritt 8, Bild 1 von 1
    • Poke out the side fan from the inside of the printer.
  9. Samsung ML2510 Side Cooling Fan Replacement: Schritt 9, Bild 1 von 1
    • Unplug the fan's wires from the side circuit board.
    • Replace the fan and reassemble the printer using reverse procedures.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
bbaustin
268 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-18, Regan Fall 2011 Mitglied von Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 2,514
