Zum Hauptinhalt wechseln
Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
Was du brauchst
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: Schritt 2, Bild 3 von 3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: Schritt 3, Bild 1 von 2 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: Schritt 3, Bild 2 von 2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: Schritt 4, Bild 1 von 1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: Schritt 5, Bild 1 von 1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: Schritt 6, Bild 1 von 1
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: Schritt 7, Bild 1 von 1
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: Schritt 8, Bild 1 von 1
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 2-1, Blackwell Fall 2016 Mitglied von USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
George, do you know where the graphics chip is at on that motherboard?
Any Where - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,205
