Zum Hauptinhalt wechseln
Macintosh Powerbook 5300cs Trackpad Replacement
Was du brauchst
  1. Macintosh Powerbook 5300cs Trackpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 2, Bild 1 von 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Trackpad Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 4, Bild 1 von 2 Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 4, Bild 2 von 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 5, Bild 1 von 3 Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 5, Bild 2 von 3 Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: Schritt 6, Bild 2 von 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: Schritt 6, Bild 3 von 3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 7, Bild 1 von 1
    • Remove the orange stripped ribbon that connects the trackpad to the rest of the laptop by carefully pulling up.
  8. Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 8, Bild 1 von 2 Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 8, Bild 2 von 2
    • With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place.
    • Then disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
  9. Macintosh Powerbook 5300cs Trackpad Replacement: Schritt 9, Bild 1 von 1
    • The trackpad can now be removed from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ronan
63 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 6-1, Regan Fall 2011 Mitglied von Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,017
