Zum Hauptinhalt wechseln
Macintosh Powerbook 5300cs Hard Drive Replacement
Was du brauchst
  1. Macintosh Powerbook 5300cs Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Hard Drive Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 4, Bild 1 von 2 Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 5, Bild 1 von 3 Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 5, Bild 2 von 3 Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 3 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: Schritt 6, Bild 2 von 3 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: Schritt 6, Bild 3 von 3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • With a Torx #9 screwdriver, remove the three .30 in. screws that hold the metal frame in place.
  8. Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 8, Bild 1 von 3 Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 8, Bild 2 von 3 Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Remove the metal chasis that holds the hard drive.
  9. Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • In order to remove the hard drive, remove the four .22 in. screws circled in red found on both sides of the metal chassis with a Torx #9 screwdriver.
  10. Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 10, Bild 1 von 2 Macintosh Powerbook 5300cs Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • Pull the hard drive out.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ronan
63 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 6-1, Regan Fall 2011 Mitglied von Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 21
Insgesamt: 1,754
