Zum Hauptinhalt wechseln
Linksys WRT54G Motherboard Replacement
Was du brauchst
  1. Linksys WRT54G Motherboard Replacement, Antennas: Schritt 1, Bild 1 von 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Replacement: Schritt 2, Bild 1 von 3 Linksys WRT54G Motherboard Replacement: Schritt 2, Bild 2 von 3 Linksys WRT54G Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Replacement: Schritt 3, Bild 1 von 3 Linksys WRT54G Motherboard Replacement: Schritt 3, Bild 2 von 3 Linksys WRT54G Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Replacement, Casing: Schritt 4, Bild 1 von 2 Linksys WRT54G Motherboard Replacement, Casing: Schritt 4, Bild 2 von 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Linksys WRT54G Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Replacement: Schritt 6, Bild 1 von 2 Linksys WRT54G Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Aaron Brown
163 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-7, Regan Fall 2011 Mitglied von Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 3,382
