Einleitung
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
Was du brauchst
To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
Pull the top piece upwards and away from the bottom to remove.
Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
Once screws have been removed, slide the motherboard in the direction of its LED lights.
Lift motherboard up and away from the black lower casing.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
