Einleitung
The Sony Ericsson s710a is a camera phone with all of the features expected of a phone in the mid '00's.
Was du brauchst
Remove the plastic piece near the base of the keypad.
Then remove the two 6mm screws beneath the plastic cover with a Phillips head screwdriver.
Use the plastic opening tool to pry off the back cover of the phone. This will require a bit of careful work.
Once you have removed the back cover, use the plastic opening tool to carefully pry out the circuit board.
Remove the LCD cable connectors coming from through the hinge hole with a flathead screwdriver.
Now the two parts of the phone are separated.
On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
When you lift this off, you will need to disconnect the cables from the other side using the same method as in Step 5.
Remove the plastic piece near the bottom of this side of the phone with the plastic opening tool. This will give you access to two additional screws.
Remove the four visible 6mm screws. Then remove the back cover.
In order to remove the LCD screen, use the plastic opening tool to pry the plastic piece from the LCD. Perform this step carefully to avoid scratching the glass screen.
In this picture, you can see all of the parts in the non-camera side of the phone.
