Zum Hauptinhalt wechseln
iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement
Was du brauchst
  1. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, Outer Base Plate: Schritt 1, Bild 1 von 2 iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, Outer Base Plate: Schritt 1, Bild 2 von 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, RAM DIMM: Schritt 3, Bild 1 von 2 iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, RAM DIMM: Schritt 3, Bild 2 von 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, AirPort Card: Schritt 4, Bild 1 von 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  5. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, Removing the Lower Case: Schritt 5, Bild 1 von 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement: Schritt 6, Bild 1 von 2 iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement: Schritt 6, Bild 2 von 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement: Schritt 7, Bild 1 von 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement: Schritt 8, Bild 1 von 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
  9. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, Internal RAM: Schritt 9, Bild 1 von 1
    • Release the tabs on each side of the module by pulling them away from the internal RAM
    • Once the tabs are pulled the module will "pop" out and you can slowly remove it.
  10. iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, PRAM Battery: Schritt 10, Bild 1 von 3 iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, PRAM Battery: Schritt 10, Bild 2 von 3 iMac G4 15" 700 MHz EMC 1873 PRAM Battery Replacement, PRAM Battery: Schritt 10, Bild 3 von 3
    • Use a spudger to gently pull the side of the battery out of the socket.
    • Remove the PRAM battery
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Ryan Kozak
1.675 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-32, Amido Fall 2011 Mitglied von Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Mitglieder
8 Anleitungen geschrieben
5 Kommentare
This is missing a description of re-doing the thermal paste which connects the heat sinks in the top part with the heat sinks in the bottom part. Check elsewhere on the internet for that (don't look at the other battery replacement guide here on ifixit, that one is criminal in how bad it is, I used to be impressed because that guy had the highest reputation in all of iFixit, now I realized he just gamed the system by putting up zillions of low-quality guides, and letting other people clean up the mess behind him.)
This heat thing is important, as your processor will overheat, and cause your mac to crash randomly.
Netmammal - Antwort
Not bad indications, thanks, however the other comment is quite right. It is too important re- doing the thermal paste , as long as in this computer is needed in more parts than any other 'conventional' PC.
More over, once you have opened the mac, I would suggest to change the cpu thermal paste too.
Saying that, my point is that this is the second time I have to change the battery and I have faced a little problem assembling the external RAM (it wont click again) … and I´m still thinking why is mandatory (or at lest it looks like) to removing the external RAM and the airport card in order to open the other part of the computer?
At far as I´m concerned there is not phisical interference with the work, is it?
euato - Antwort
To replace the PRAM battery you only need steps 1, 2, 5, 6 and 10. Or check out this guide instead, which includes the thermal paste step: iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement
Tobias Smollett - Antwort
Thanks Tobias
Hubi C - Antwort
Can someone share the battery type. It looks like a 1/2 AA battery, but all of my reference material refers to an Apple part number without any cross-reference to standard battery types.
Can someone who has the ability to do so confirm that it is a 1/2 AA 3.6v Lithium cell? And if it's not, is it some other standard type?
David Charlap - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 100
Insgesamt: 19,533
