Zum Hauptinhalt wechseln
One Education Infinity:One Battery Replacement
Was du brauchst
  1. One Education Infinity:One Battery Replacement, Top Case: Schritt 1, Bild 1 von 3 One Education Infinity:One Battery Replacement, Top Case: Schritt 1, Bild 2 von 3 One Education Infinity:One Battery Replacement, Top Case: Schritt 1, Bild 3 von 3
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: Schritt 2, Bild 1 von 2 One Education Infinity:One Battery Replacement, Battery: Schritt 2, Bild 2 von 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: Schritt 3, Bild 1 von 3 One Education Infinity:One Battery Replacement: Schritt 3, Bild 2 von 3 One Education Infinity:One Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: Schritt 4, Bild 1 von 3 One Education Infinity:One Battery Replacement: Schritt 4, Bild 2 von 3 One Education Infinity:One Battery Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Taylor Bratsch
5.742 Reputation
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 983
