Einleitung
This guide will demonstrate how to replace the motherboard in your One Education Infinity:One laptop.
Was du brauchst
Use a spudger to disconnect the black bundled cable connector from the motherboard.
Use a spudger to lift the black tab on top of the ZIF connector.
Slide the ribbon cable out of the connector.
Use a spudger to flip up the black retaining flap on the ZIF connector.
Pull the folded ribbon cable straight out of the connector.
Use a spudger to flip up the black flap on the camera's ZIF connector.
Pull the ribbon cable straight out of the connector.
Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
