Zum Hauptinhalt wechseln
One Education Infinity:One Motherboard Replacement
Was du brauchst
  1. One Education Infinity:One Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 One Education Infinity:One Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Motherboard Replacement: Schritt 2, Bild 1 von 3 One Education Infinity:One Motherboard Replacement: Schritt 2, Bild 2 von 3 One Education Infinity:One Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Motherboard Replacement: Schritt 3, Bild 1 von 3 One Education Infinity:One Motherboard Replacement: Schritt 3, Bild 2 von 3 One Education Infinity:One Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Motherboard Replacement, Antenna: Schritt 5, Bild 1 von 2 One Education Infinity:One Motherboard Replacement, Antenna: Schritt 5, Bild 2 von 2
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
  6. One Education Infinity:One Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 One Education Infinity:One Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 One Education Infinity:One Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Use tweezers to pull the dock connection cable away from the motherboard.
  8. One Education Infinity:One Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
  9. One Education Infinity:One Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Lift the protective shield away from the motherboard.
  10. One Education Infinity:One Motherboard Replacement: Schritt 10, Bild 1 von 3 One Education Infinity:One Motherboard Replacement: Schritt 10, Bild 2 von 3 One Education Infinity:One Motherboard Replacement: Schritt 10, Bild 3 von 3
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  11. One Education Infinity:One Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the motherboard away from the display assembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Taylor Bratsch
5.742 Reputation
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 489
