Zum Hauptinhalt wechseln
Magellan RoadMate 5120-LMTX Speaker Replacement
Was du brauchst
  1. Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 3 Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 3 Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Speaker Replacement: Schritt 2, Bild 1 von 3 Magellan RoadMate 5120-LMTX Speaker Replacement: Schritt 2, Bild 2 von 3 Magellan RoadMate 5120-LMTX Speaker Replacement: Schritt 2, Bild 3 von 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: Schritt 3, Bild 1 von 2 Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: Schritt 3, Bild 2 von 2
    • Open the device and remove the tape from the speaker wire using the spudger.
  4. Magellan RoadMate 5120-LMTX Speaker Replacement: Schritt 4, Bild 1 von 2 Magellan RoadMate 5120-LMTX Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 4mm Phillips #00 screws securing the speaker assembly and remove speaker.
Abschluss
IUPUI, Team 4-4, Wilson Fall 2016 Mitglied von IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 138
