Einleitung
The speaker removal process is easy to accomplish. The device has wires that can be damaged if you are not careful when opening the device. There will be tape holding some of the wires in place. Make sure to retain the tape or have more tape on hand so that it can be reapplied when reassembling your RoadMate.
Was du brauchst
Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
Use a spudger to disconnect the speaker connection from the motherboard.
Open the device and remove the tape from the speaker wire using the spudger.
Remove the two 4mm Phillips #00 screws securing the speaker assembly and remove speaker.
