Einleitung
If your Magellan RoadMate is experiencing positioning issues it may have a faulty GPS antenna. Here are the steps for replacing your Magellan RoadMate 5120-LMTX GPS Antenna. This replacement does involve a very simple soldering of a connection.
Was du brauchst
Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
Use a spudger to disconnect the speaker connection from the motherboard.
There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
Carefully lift the motherboard out of the plastic housing by the edges while guiding the ribbon cable through the slot.
Store the motherboard on a safe non-conductive surface, preferably an anti-static mat.
Remove the two 2.4mm Phillips #00 screws that hold the antenna to the motherboard.
Flip the motherboard over and locate the soldered antenna connection.
Melt the existing solder with the tip of your soldering iron while gently pulling on the antenna. The antenna should come off easily.
To reassemble your device, follow all instructions before soldering step in reverse order.
