Was du brauchst
With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
Use the Spudger to remove the copper colored light bulb clip.
Remove the front cover entierly from the camera body.
From the top view of the camera, remove the one 5.8 mm screw.
From the top view of the camera, remove the one 2.8 mm screw
The mother board is permanently fixed to the battery housing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
