Zum Hauptinhalt wechseln
iBook G4 14" 1.42 GHz DC-In Board Replacement
Was du brauchst
  1. iBook G4 14" 1.42 GHz DC-In Board Replacement, Battery: Schritt 1, Bild 1 von 2 iBook G4 14" 1.42 GHz DC-In Board Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 14" 1.42 GHz DC-In Board Replacement, Lower Case: Schritt 2, Bild 1 von 1
    • Close the display and flip the computer over.
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The shorter screw is in the center.
  3. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
  4. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 4, Bild 1 von 1
    • Remove the three newly-revealed Phillips screws.
    • One screw is underneath each bumper (three total).
  5. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  6. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the two Phillips screws on either side of the battery contacts.
  7. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 7, Bild 1 von 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push in the thin rims of the lower case surrounding the battery compartment, bending them past the tabs, and then lift up to free that corner of the lower case.
  8. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 8, Bild 1 von 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  9. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 9, Bild 1 von 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  10. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 10, Bild 1 von 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  11. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 11, Bild 1 von 1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  12. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 12, Bild 1 von 1
    • The front and sides of the lower case are now free.
    • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
  13. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 13, Bild 1 von 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  14. iBook G4 14" 1.42 GHz DC-In Board Replacement, Bottom Shield: Schritt 14, Bild 1 von 1
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  15. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 15, Bild 1 von 1
    • Lift the bottom shield off.
  16. iBook G4 14" 1.42 GHz DC-In Board Replacement, DC-In Board: Schritt 16, Bild 1 von 1
    • Remove the single Phillips screw securing the DC-In board.
  17. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 17, Bild 1 von 1
    • Angle the DC-In board out of its compartment.
    • You may need to remove tape that secures the DC-In board cable to the case.
  18. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 18, Bild 1 von 1
    • Lift the DC-In cable from the adhesive attaching it to the logic board.
  19. iBook G4 14" 1.42 GHz DC-In Board Replacement: Schritt 19, Bild 1 von 1
    • Disconnect the DC-In cable from the logic board.
    • Wiggling the connector parallel to the surface of the logic board while applying slight tension may aid in removal.
Abschluss
63 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
4 Kommentare
On my older iBook G4 the screws where a 5/64 allen head 1.1ghz model
Keith - Antwort
it was my first time opening up a laptop and I did not have any problem this tutorial is very helpful because it shows you the process step by step something hard to find nowadays
Baye - Antwort
This was a really easy guide thanks. I had ordered a replacement DC in board but found after opening I could have probably repaired the existing one. It had been tripped over a few too many times. I think a bit of re-soldering on the connector where the tape covers in step 17 may have fixed mine. Now I have a backup at least.
datarez - Antwort
Hi,
Does anyone happen to know the values of the L2 and L3 parts on this DC-in board?
I am looking to reuse them but I cannot find any specs.
Thank you and regards,
Vincent
Vincent Gerris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 20,558
