Zum Hauptinhalt wechseln
Nikon Coolpix S9700 Flash Housing Replacement
Was du brauchst
  1. Nikon Coolpix S9700 Flash Housing Replacement, Battery: Schritt 1, Bild 1 von 2 Nikon Coolpix S9700 Flash Housing Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Flash Housing Replacement: Schritt 2, Bild 1 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 2, Bild 2 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 2, Bild 3 von 3
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Flash Housing Replacement: Schritt 3, Bild 1 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 3, Bild 2 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 3, Bild 3 von 3
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Flash Housing Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 4, Bild 2 von 2
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: Schritt 5, Bild 1 von 3 Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: Schritt 5, Bild 2 von 3 Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: Schritt 5, Bild 3 von 3
    • Place your fingernail or a plastic opening tool in the space between the camera housing and the flash housing.
    • Carefully pry up on the flash housing. It will pop up automatically.
  6. Nikon Coolpix S9700 Flash Housing Replacement: Schritt 6, Bild 1 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 6, Bild 2 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 4-mm J000 screws positioned at the bottom of the flash housing.
    • The housing will now be hanging only by the ribbon supplying power.
  7. Nikon Coolpix S9700 Flash Housing Replacement: Schritt 7, Bild 1 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 7, Bild 2 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 7, Bild 3 von 3
    • Using your fingers or plastic opening tool, remove the back half from the front half of the flash housing. The front half will stay on.
    • Sudden or large force can rip the flash power supply off.
  8. Nikon Coolpix S9700 Flash Housing Replacement: Schritt 8, Bild 1 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 8, Bild 2 von 3 Nikon Coolpix S9700 Flash Housing Replacement: Schritt 8, Bild 3 von 3
    • Place a plastic opening tool on the clear lens of the flash.
    • Gently push on the lens to remove the front half of the flash housing.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Matt Staubus
849 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 9-5, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
I dropped my coopix and cannot get it back in. Is there a way to replace the flash?
Charles Cezeaux - Antwort
Dropped my Nikon Coolpix S9700 and broke the flash. It will not go back inside camera. Can it be replaced or repaired?
Does anyone know if it can be replaced or repaired?
I have done this to my camera. Cannot find replacement for flash. Can i use the camera as is?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 976
