Zum Hauptinhalt wechseln
Casing and Trigger
Was du brauchst
  1. Casing and Trigger, Fellowes T7CM Casing and Trigger Replacement: Schritt 1, Bild 1 von 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Casing and Trigger: Schritt 2, Bild 1 von 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
  3. Casing and Trigger: Schritt 3, Bild 1 von 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Casing and Trigger: Schritt 4, Bild 1 von 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
John Wisthoff
487 Reputation
3 Anleitungen geschrieben
IUPUI, Team 2-2, Baechle Fall 2016 Mitglied von IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Mitglieder
16 Anleitungen geschrieben
2 Kommentare
-Group 1 Recommendations-
Use Caution - Should use the 'Caution' bullet. (Click on the bullet to change bullets)
Take note - Should use the 'Note' bullet.
Second to last bullet on the last step - Should be a note because it is not stating a step, it is a note or reminder for the user.
Deanna Jack - Antwort
Where can i buy replacement gears for this shredder?
indymoon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 55
Insgesamt: 3,668
