Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Casio Watch zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Casio Digital Watch Teardown, Casio Digital Watch: Schritt 1, Bild 1 von 1
    • This is a teardown of a Casio Digital Watch down to the internal circuitry.
    • You will need a small Phillips screwdriver for this teardown.
  2. Casio Digital Watch Teardown, Remove the Case: Schritt 2, Bild 1 von 1
    • Carefully remove the four screws on the backside of the watch.
    • You will need an extremely small screwdriver. A screwdriver to repair glasses would work.
  3. Casio Digital Watch Teardown, Gently Push out the Screen: Schritt 3, Bild 1 von 2 Casio Digital Watch Teardown, Gently Push out the Screen: Schritt 3, Bild 2 von 2
    • Press your fingers on the screen and remove the watch from its case.
    • Be sure to save the three buttons that control the watch
  4. Casio Digital Watch Teardown, Remove the Battery Holder: Schritt 4, Bild 1 von 3 Casio Digital Watch Teardown, Remove the Battery Holder: Schritt 4, Bild 2 von 3 Casio Digital Watch Teardown, Remove the Battery Holder: Schritt 4, Bild 3 von 3
    • Remove the Battery Holder surrounding the circuitry of the watch by carefully pulling off each of the four clips.
  5. Casio Digital Watch Teardown, Remove the Battery: Schritt 5, Bild 1 von 1
    • Remove the battery by pulling from the sides to unstick the adhesive.
  6. Casio Digital Watch Teardown, Detach the LCD: Schritt 6, Bild 1 von 2 Casio Digital Watch Teardown, Detach the LCD: Schritt 6, Bild 2 von 2
    • Remove the four plastic pins connecting the LCD and remove the LCD holder
  7. Casio Digital Watch Teardown, Teardown Complete: Schritt 7, Bild 1 von 1
    • This reveals the internal circuitry of the watch, and the teardown is complete.
Cooper
457 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 24-6, Green Winter 2015 Mitglied von Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Mitglieder
15 Anleitungen geschrieben
2 Kommentare
This is my Casio 5 alarm tear down. Can u tell me if this has anything on it that u guys didn't do. Please email me at dolphinzpride@gmail.com...
https://linksharing.samsungcloud.com/wQ5...
Skylar Miller - Antwort
I have casio illuminator dual time watch, it was damaged outerward accidentally , but internal systems r safe. But now its digits r not displaying properly, sometimes digit parts r missing n sometimes fully 888888 r shown
Sarabjeet Singh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 116
Insgesamt: 12,710
