Zum Hauptinhalt wechseln
One Education Infinity:One Daughterboard Replacement
Was du brauchst
  1. One Education Infinity:One Daughterboard Replacement, Back Case: Schritt 1, Bild 1 von 2 One Education Infinity:One Daughterboard Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Daughterboard Replacement: Schritt 2, Bild 1 von 2 One Education Infinity:One Daughterboard Replacement: Schritt 2, Bild 2 von 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Daughterboard Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Daughterboard Replacement: Schritt 4, Bild 1 von 2 One Education Infinity:One Daughterboard Replacement: Schritt 4, Bild 2 von 2
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Daughterboard Replacement, Daughterboard: Schritt 5, Bild 1 von 2 One Education Infinity:One Daughterboard Replacement, Daughterboard: Schritt 5, Bild 2 von 2
    • Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
    • Pull the ribbon cable straight out of the ZIF connector.
  6. One Education Infinity:One Daughterboard Replacement: Schritt 6, Bild 1 von 2 One Education Infinity:One Daughterboard Replacement: Schritt 6, Bild 2 von 2
    • Use the flat end of a spudger to flip up the black tab on the smaller ZIF connector.
    • Use tweezers to pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Daughterboard Replacement: Schritt 7, Bild 1 von 3 One Education Infinity:One Daughterboard Replacement: Schritt 7, Bild 2 von 3 One Education Infinity:One Daughterboard Replacement: Schritt 7, Bild 3 von 3
    • Use a Phillips #000 screwdriver to unscrew the three 3.4mm screws.
    • Lift the daughterboard away from the device to remove.
Abschluss
Taylor Bratsch
5.730 Reputation
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 243
