Zum Hauptinhalt wechseln
Dell Inspiron 1525 Central Control Cover Replacement
Was du brauchst
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 1525 Central Control Cover Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: Schritt 3, Bild 1 von 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 1525 Central Control Cover Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 1525 Central Control Cover Replacement: Schritt 4, Bild 3 von 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 1525 Central Control Cover Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 1525 Central Control Cover Replacement: Schritt 5, Bild 3 von 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 3,591
