Zum Hauptinhalt wechseln
HP Pavilion dv2913cl WiFi receiver Replacement
Was du brauchst
  1. HP Pavilion dv2913cl WiFi receiver Replacement, WiFi receiver: Schritt 1, Bild 1 von 1
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. HP Pavilion dv2913cl WiFi receiver Replacement: Schritt 2, Bild 1 von 1
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. HP Pavilion dv2913cl WiFi receiver Replacement: Schritt 3, Bild 1 von 1
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  4. HP Pavilion dv2913cl WiFi receiver Replacement: Schritt 4, Bild 1 von 2 HP Pavilion dv2913cl WiFi receiver Replacement: Schritt 4, Bild 2 von 2
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
Abschluss
Adam Braga
230 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 115
