Zum Hauptinhalt wechseln
Epson Stylus NX240 Side Buttons Replacement
Was du brauchst
  1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: Schritt 1, Bild 1 von 2 Epson Stylus NX240 Side Buttons Replacement, Side Buttons: Schritt 1, Bild 2 von 2
    • Go to the left side of the printer and locate the control panel with the buttons on it.
    • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
  2. Epson Stylus NX240 Side Buttons Replacement: Schritt 2, Bild 1 von 1
    • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
  3. Epson Stylus NX240 Side Buttons Replacement: Schritt 3, Bild 1 von 1
    • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
  4. Epson Stylus NX240 Side Buttons Replacement: Schritt 4, Bild 1 von 1
    • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • The plastic part of the control panel is now separate.
  5. Epson Stylus NX240 Side Buttons Replacement: Schritt 5, Bild 1 von 1
    • Flip over the plastic part of the now separated control panel.
    • Remove the buttons by pulling them up with your fingers.
  6. Epson Stylus NX240 Side Buttons Replacement: Schritt 6, Bild 1 von 1
    • All parts should be separate now to clean or replace.
Abschluss
Joshua Fabel
104 Reputation
1 Anleitung geschrieben
University of Maine, Team 2-4, Diaz Fall 2016 Mitglied von University of Maine, Team 2-4, Diaz Fall 2016
UMAINE-DIAZ-F16S2G4
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 563
