Zum Hauptinhalt wechseln
Garmin Nuvi 255W Battery Replacement
Was du brauchst
  1. Garmin Nuvi 255W Battery Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Battery Replacement: Schritt 3, Bild 1 von 2 Garmin Nuvi 255W Battery Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Battery Replacement: Schritt 4, Bild 1 von 2 Garmin Nuvi 255W Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the power button.
  5. Garmin Nuvi 255W Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Battery Replacement: Schritt 6, Bild 1 von 2 Garmin Nuvi 255W Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Battery Replacement: Schritt 7, Bild 1 von 2 Garmin Nuvi 255W Battery Replacement: Schritt 7, Bild 2 von 2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
Timothy
73 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 9-3, Regan Winter 2012 Mitglied von Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Mitglieder
4 Anleitungen geschrieben
9 Kommentare
Thanks for this very nicely illustrated guide.
RBStorms - Antwort
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
rbol - Antwort
Used these instructions to replace battery in my 5-year old Garmin nuvi 205W (which has the same access and internal geometry).
JRedmond - Antwort
Thanks, great demonstration.
peter2x4 - Antwort
This is great! I have run into a big problem, though. One of the screws is "unthreaded." The head has become smooth, and I can't unscrew it to get the cover off. Is there any way to get it off???
nancyw - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 49
Insgesamt: 26,688
