Was du brauchst
Remove the two 2.9 mm screws from the side panel closest to the camera lens.
Pull the back panel away from the camera body, starting at the end with the function buttons.
Remove the front cover by gently pulling it away from the camera body.
Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
Push the metal frame away from the metal tab using the spudger to detach the frame.
Rotate the metal frame upwards.
Carefully lift the metal frame from the camera.
Remove the black LCD screen, leaving the thin lens pieces in place.
Carefully pull on the orange connector ribbon to disconnect the LCD screen.
The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Very helpful. These units still sell for a lot more than the cost of the replacement LCD
