Zum Hauptinhalt wechseln
LG Muziq LX570 Keypad Replacement
Was du brauchst
  1. LG Muziq LX570 Keypad Replacement, Battery: Schritt 1, Bild 1 von 2 LG Muziq LX570 Keypad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Keypad Replacement: Schritt 2, Bild 1 von 2 LG Muziq LX570 Keypad Replacement: Schritt 2, Bild 2 von 2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Keypad Replacement, Rear Case: Schritt 3, Bild 1 von 2 LG Muziq LX570 Keypad Replacement, Rear Case: Schritt 3, Bild 2 von 2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Keypad Replacement: Schritt 4, Bild 1 von 3 LG Muziq LX570 Keypad Replacement: Schritt 4, Bild 2 von 3 LG Muziq LX570 Keypad Replacement: Schritt 4, Bild 3 von 3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
  5. LG Muziq LX570 Keypad Replacement, Motherboard: Schritt 5, Bild 1 von 3 LG Muziq LX570 Keypad Replacement, Motherboard: Schritt 5, Bild 2 von 3 LG Muziq LX570 Keypad Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Use the spudger to lift the motherboard from the phone.
  6. LG Muziq LX570 Keypad Replacement, Keypad: Schritt 6, Bild 1 von 3 LG Muziq LX570 Keypad Replacement, Keypad: Schritt 6, Bild 2 von 3 LG Muziq LX570 Keypad Replacement, Keypad: Schritt 6, Bild 3 von 3
    • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
    • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
    • Use the spudger to detach the circuit board from the phone.
  7. LG Muziq LX570 Keypad Replacement: Schritt 7, Bild 1 von 3 LG Muziq LX570 Keypad Replacement: Schritt 7, Bild 2 von 3 LG Muziq LX570 Keypad Replacement: Schritt 7, Bild 3 von 3
    • Open the phone to expose the keypad.
    • Use your finger to push the keypad from the front towards the circuit board.
    • Remove the keypad from the phone.
Abschluss
Braden Burk
1 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-29, Amido Winter 2012 Mitglied von Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 694
