Zum Hauptinhalt wechseln
Canon PowerShot SD1000 Flash Unit Replacement
Was du brauchst
  1. Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: Schritt 1, Bild 1 von 2 Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 4, Bild 1 von 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 5, Bild 1 von 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Flash Unit Replacement, Front Case: Schritt 6, Bild 1 von 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 7, Bild 1 von 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Flash Unit Replacement, LCD Screen: Schritt 8, Bild 1 von 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 9, Bild 1 von 2 Canon PowerShot SD1000 Flash Unit Replacement: Schritt 9, Bild 2 von 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 10, Bild 1 von 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 11, Bild 1 von 2 Canon PowerShot SD1000 Flash Unit Replacement: Schritt 11, Bild 2 von 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 12, Bild 1 von 3 Canon PowerShot SD1000 Flash Unit Replacement: Schritt 12, Bild 2 von 3 Canon PowerShot SD1000 Flash Unit Replacement: Schritt 12, Bild 3 von 3
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: Schritt 13, Bild 1 von 2 Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: Schritt 13, Bild 2 von 2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 14, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 15, Bild 1 von 1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Flash Unit Replacement: Schritt 16, Bild 1 von 2 Canon PowerShot SD1000 Flash Unit Replacement: Schritt 16, Bild 2 von 2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 8-18, Maness Winter 2012 Mitglied von Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 3,152
