Zum Hauptinhalt wechseln
Garmin GPS V Display Replacement
Was du brauchst
  1. Garmin GPS V Display Replacement, Logic Board: Schritt 1, Bild 1 von 3 Garmin GPS V Display Replacement, Logic Board: Schritt 1, Bild 2 von 3 Garmin GPS V Display Replacement, Logic Board: Schritt 1, Bild 3 von 3
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
  2. Garmin GPS V Display Replacement: Schritt 2, Bild 1 von 2 Garmin GPS V Display Replacement: Schritt 2, Bild 2 von 2
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
  3. Garmin GPS V Display Replacement: Schritt 3, Bild 1 von 2 Garmin GPS V Display Replacement: Schritt 3, Bild 2 von 2
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
  4. Garmin GPS V Display Replacement: Schritt 4, Bild 1 von 2 Garmin GPS V Display Replacement: Schritt 4, Bild 2 von 2
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
  5. Garmin GPS V Display Replacement: Schritt 5, Bild 1 von 3 Garmin GPS V Display Replacement: Schritt 5, Bild 2 von 3 Garmin GPS V Display Replacement: Schritt 5, Bild 3 von 3
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
  6. Garmin GPS V Display Replacement: Schritt 6, Bild 1 von 2 Garmin GPS V Display Replacement: Schritt 6, Bild 2 von 2
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
  7. Garmin GPS V Display Replacement: Schritt 7, Bild 1 von 1
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
  8. Garmin GPS V Display Replacement, Button Pad: Schritt 8, Bild 1 von 3 Garmin GPS V Display Replacement, Button Pad: Schritt 8, Bild 2 von 3 Garmin GPS V Display Replacement, Button Pad: Schritt 8, Bild 3 von 3
    • Gently pry the button pad off of the front plate.
  9. Garmin GPS V Display Replacement, Display: Schritt 9, Bild 1 von 3 Garmin GPS V Display Replacement, Display: Schritt 9, Bild 2 von 3 Garmin GPS V Display Replacement, Display: Schritt 9, Bild 3 von 3
    • Orient the front plate of the device so the display board is facing up.
    • With the spudger, gently work your way around the display assembly.
    • NOTE: The display assembly is composed of three parts and is glued to the case. Be careful to not separate it when prying it out.
    • Pry the display free of the front plate.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Connor
194 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 3-25, Amido Winter 2012 Mitglied von Cal Poly, Team 3-25, Amido Winter 2012
CPSU-AMIDO-W12S3G25
4 Mitglieder
Ein Kommentar
This is very helpful - especially when having problems with display (vertical or horizontal lines missing). With your detailed aid it is possible, to remove the display connector, to softly grind it, making contacts conductive again, cleaning them and reassembly the connector - then display was healed - really great help!!
schlappfinger - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 3,933
