Zum Hauptinhalt wechseln
Sansa e260R Front Panel Replacement
Was du brauchst
  1. Sansa e260R Front Panel Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Front Panel Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Front Panel Replacement: Schritt 3, Bild 1 von 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Front Panel Replacement, Battery: Schritt 4, Bild 1 von 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Front Panel Replacement, Front Panel: Schritt 5, Bild 1 von 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Front Panel Replacement: Schritt 6, Bild 1 von 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Front Panel Replacement: Schritt 7, Bild 1 von 2 Sansa e260R Front Panel Replacement: Schritt 7, Bild 2 von 2
    • Pull the front cover away from the rest of the device.
Abschluss
Casey Smith
111 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 8-15, Maness Winter 2012 Mitglied von Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 1,980
